Discuss Suggestions please ............... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Being a bit lazy. Got a landlord who wants 3 or 4 LED lights fitted in their flat ......... nothing special but they need to be warm white output.
Can be like bulkhead fittings
Ta
i remove the grommet if more than 1 cable. casing is plastic anyway.
Ah the ones I use have a metal base and an oval cable entry with hard plastic grommet, managed 3 x 1mm T&Es through it all side on. :) 3 port Ideal connector for the PLs.
Reply to Suggestions please ............... in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
