Discuss Suitable fused isolator for CU change in the Electrical Tools and Products area at ElectriciansForums.net
Amp David
Mentor
Have to price for a CU swap and the customer wants it moving into the house from the garage. Its a run of around 7 meters from the meter to the new position and will be running it in SWA.
When doing similar jobs, which kind of fused isolator is most popular with others, or is it a case of buy whatevers in stock at the time.
Cheers:cool:
If using the KMF style version with SWA, after glanding off into a steel adaptable box, would you just mount the KMF up close to the adaptable box and run the cores through to it. Not sure what type of knockouts or entry point the KMF switches have.
Thanks again
KMF perhaps not as suitable for SWA as the wylex metalclad, as you could gland straight into the wylex.
Another aspect of the wylex I like is the 'doubled' supply terminals which allows you to tail in & out to another switchfuse or CU for instance.
and cheaper as well. though i think the click unit is prettier. My lady's just asked me if they come in pink, ffs.
NICE! as i've got to put a 2 way CU in near to the meter to feed his garage, a 16 amp welder socket and 20 amp radial with spur for lights.
Saves having to faff around with Henleys
Reply to Suitable fused isolator for CU change in the Electrical Tools and Products area at ElectriciansForums.net
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Can someone sanity check my thinking please.... An 80 amp PME service head, tails to meter, 25 sq mm tails into an enclosed fused isolator with...
Hi all, I am looking to replace an existing CU (ground floor) and put it in a new position (first floor). The existing CU is on the inside of a...
Hello All, new to the forum. Would be grateful for advice on whether the following proposal is an acceptable solution or open to any suggestions...
5K
