Discuss Suitable RCBO for old GE consumer unit in the UK Electrical Forum area at ElectriciansForums.net
All that does is confirm what countless people should not have been doing in the first place.
No it doesnt.Dont forget the new regs say you cant mix mcb brands
Also to add, we can work to either version of BS7671, so you are wrong on 2 counts.Dont forget the new regs say you cant mix mcb brands
Doesnt it state, it must comply with the manufacturers standards, if it doesn't you are taking responsibility that it will be fine.You have always had to follow manufacturers instructions, this new Reg is just reinforcing what is essentially against such instructions.
that would suggest that such a person would then have to get the CU tested to the relevant standard and also get it CE approved?Final sentence of Note 2, 536.4.203:
If an assembly deviates from its original manufacturer's instructions, or includes components not included in the original verification , the person introducing the deviation becomes the original manufacturer with the corresponding obligations.
Precisely.that would suggest that such a person would then have to get the CU tested to the relevant standard and also get it CE approved?
Precisely.
Precisely.
I personally think its a good safety based reminder. How many potentially unsafe situations have you come across from wrongly suited breakers wedged into boards ? I have seen loads. Its also an industry wide semi accepted Bodge.How many fuseboard manufacturers on JPEL / 64
That reg smacks of vested interests ....
Wonder how anybody thinks this will be enforced ?
Reply to Suitable RCBO for old GE consumer unit in the UK Electrical Forum area at ElectriciansForums.net
