Discuss Sunny boy software in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
W
woko
Hi, Im trying to match an inverter to 9 Suntech 190 24AD+ Mono panels. It wont allow 9 in one string but will allow 2 strings of 4.
I'm trying to get it to show 1 string of 4 and 1 string of 5, is this possibe or am I not using the software properly?
TIA
Woko
SB2000HF should be fine (single string 9 panels) though it's a bit oversized - what software are you using?
Try a Fronius or a Power-One
Using the SMA software, is there any fronius software I can use? I'm not really in a position to buy Pvsol yet.
I used the SMA Sunny design too, it configures just fine with 1 string x 9 panels and the SB2000HF, it tells you though that it's 'conditionally compatible' becuase it's oversized.
The SB1700 is overpowered at 9 panels (over voltage) so as it only has a single MPP tacker with split input the two strings must contain IDENTICAL strings i.e. orientation, elevation, panel make and model and # of panels. hence it offers 2 x X, (2 x 5 is under voltage) however it is the wrong inverter for that installation. - Use something else.
Reply to Sunny boy software in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hello- I have a recent solar panel installation at my home in Rio de Janeiro Brazil. Specs: 9.6kWp, 24x 400W panels (Canadian Solar), 8.2kW...
Hi there! I'm new in the forum. This time I bring a question about inverters. I was hired to oversee the Electrical Installation of a...
I am new to the forum so Hi to everyone out there! I am also a new DIY Solar PV user and I am looking for some technical advice on an unusual...
