slrichardson
After some thoughts on this.
Been changing a consumer unit at an old house. The cabling is mostly rubber with some pvc cables.
All IR'd ok, but the lighting has no earth at light points and switches although there is one at the c/u. There are also some sockets on the lighting circuit that have an earth.
Thinking there is a jb system for the lights.
The client will be comprehensively refurbishing in the new year. Rewiring replumbing etc.
What are your thoughts on the supp. bonding situation.
Should i try and get a connection or do i make a note on the eic
Over to you
Over to you
