Discuss Suppliers fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
craig1000
How do i go about finding out the size type of suppliers fuse/cutout without cutting their tags? is there any numbers i could ring , someone who would hold that info? Obviousley need that info to complete EIC!
you can trey DNO, but by the time you get put through to someone who knows what you're talking about, you will have used up all your credit on your mobile, only to be told " ain't got a clue, mate". best to enter N/V on your test results.
Reply to Suppliers fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
My customer has had a completely new supply installed to his garage. The DNO has not put a fuse in the cut out though. I'm guessing he needs to...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
