Electrical2Go - Online Electrical Supplier
Discuss Supply cable in loft space in the Electrical Forum area at ElectriciansForums.net
Steve g
Hi,
Can any one confirm / advise if the following situation is 'allowed ' with current safety regulations. A 160 year old row of terraced cottages with open loft space running through all 5 . The 10 16mm supply cables enter the building at one end and are drapped over the ceiling timbers very randomly , they then drop down to each cottage to a meter on the landing . Much of the cable has been covered with insulation and people have stored the normal 'loft' storage stuff on top of them . There seems to be a big safety issue here !
The owner of the first cottage wants to insulate and board out the loft and build a Fire wall between the next cottage's loft space, as was advised by the surveyor. Can he request or even insist that the cables to the other cottages are removed from his loft and re- routed ; probably outside .
Wetroom Store - Network Wetroom Suppliers
T
TonyM58
  • #2
Pretty sure he can insist. Obviously the cables have a reduced rating because of the insulation and are liable to suffer mechanical damage.
If the supplier is reluctant (which they will be) I would threaten them with charging them rent (including back rent) for the use of his loft space - if they put a pylon in a farmers field he would get rent, so it should be the same!
Steve g
  • #3
Thanks for your thoughts Tony. Does any one know of any written standards that they 'have ' to comply with on their side of the meter. that could be quoted to them. Everthing is so precise now on 'our' side of the meter.
Steve g
  • #4
I have now attached a photo of the offending supply wires...any more thoughts ??
N
nickblake
  • #5
One thing you could point out , you need to provide full isolation for the installation , its an accessable loft , how can it be isolated ,especially if its from another property .
M
mogga
  • #6
you will possibly find fuse of some sort either outside where they enter the building or on the pole at transformer
as for getting the DNO to remove request this without mentioning the Rented space option as they will no doubt go for the rented space option if offered
As for the 5 lofts being linked check ith LA regarding this as they may request firewalls to seperate loft areas
M
mogga
  • #7
Iv just checked the picture FFS looks like a big electric spiders just vomited cables IMO if they go for rented space demand they fit trunking to provide mechanical proection and move cables from central area of loft At their cost
mechelec
I would think you will all end up with bills for service alterations because when the DNO installed the cables it complied with their installation regulations and they do not go round upgrading installs to current specs.
I wired a conversion two years ago which had the same problem, the customer got in touch with the leccy board (EDF) at the time and told them that the loft space was being converted so can they remove their cables which they done at their (considerable) cost, they had to put new pole at the rear of the property and then rewired all the houses from this pole by "moling" to the back wall and then up the back wall of each house !! I am glad i didn`t have to pay for it
Reply to Supply cable in loft space in the Electrical Forum area at ElectriciansForums.net
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
