Discuss Supply cable info in the DIY Electrical Advice area at ElectriciansForums.net
Hi all,
Apologies for possibly a basic question. I’ve just gotten a job as a ‘maintenance man’ for a local housing company, my role is pretty basic mostly joinery, decorating works. Don’t worry, the nearest I’ll get to doing anything with electrics is changing lamps. But I’m hoping to start getting on top of paperwork and creating logs / directories for the properties we have.
One of our properties is a building separated into 4 flats. Can anyone tell me if this supply is three phase or single? I assumed 3 but there appears to be no neutral or earth cable.
I would say that is three phase. The taped-up conductor on the right is a PEN conductor (protective earth neutral). It probably connects to a bar where both the outgoing neutrals and earthing conductors are connected. A TN-C-S earthing system.
Reply to Supply cable info in the DIY Electrical Advice area at ElectriciansForums.net
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
I am doing a new consumer unit install on a second story ex council flat. I’ve notice the mains come in in metal conduit with no CPC. On checking...
Hi, I’m after some advice for an existing car charger that’s on one of our newly inherited sites. We have a Rolec 2x 7.2kw pedestal charger, just...
Hi All, I’m after some advice. I’ll cut to the chase but I can give more detail if needed. A 400A sub main supply needs to be ran 100m, a pretty...
