Discuss Supply to intruder alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Y
YTSOxford
Hi all. Have just installed an alarm, but am umin and ar'ing about whether to put the 6A MCB on the unprotected side of the board.
Its on the RCD side at the moment, but the main box of the alarm is in the same cupboard as the fuse boards The supply comes to it surface mounted in conduit, straight from the board & was thinking it'll be good incase the RCD trips, the alrm wouldn't...but am also thinking some of the alarm cables are in the wall... What do you guys think?
Reply to Supply to intruder alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
