Discuss Supplying a converted Bus in the UK Electrical Forum area at ElectriciansForums.net
TDG
First time poster.
I’m hoping to get a bit of insight for a business I’m starting up.
I’m converting a double decker bus (Volvo B7TL) into a shop. I’m interested in how much power I would need to light and heat the thing, and the best way of getting an external power supply.
The bus was powered by two twelve volt batteries, but my intention is to set up an external supply. We will need to power:
- Inbuilt lighting (standard fitting)
- Already fitted CCTV
- Already fitted bus heating
- Electronic devices (lap-top, IZettle electronic till, 32 inch TV screen, 3-4 small electric devices, e.g - cameras, battery charges for IPhones’ and camera batteries)
I want to know if a domestic feed will be enough to power it all, and a rough idea of what the wattage would be? And how / how easy it would be to wire it all together? The bus will be static and based in central London.
It would also be great to know the best sustainable way of doing this, how many solar panels would I need.
Thanks,
TDG
Have a look in section 717 of BS7671 for mobile and transportable units.
Most units like this will have a 'ceeform' inlet at either 16A or 32A.
Take note about chassis bonding and cable type for the install (usually flex) bootlaces ferulls on the cable ends help.
Generator or mains to power the unit.
If you have a street pillar supply for the unit make sure the earting is not TNC-S (PME) as its prohibited for use (apart from a few circumstances where a competent person is present)
Although not strictly 'entertainment' BS7909 is best practice with it being a temporary supply. Also in a inner city location you need to look at other electrical environments around it.
Diesel heaters are good and will considerably lower your max demand.
Go on,Tel,explain how you got bus-jacked,by a goofy crooner and his crying walking sleeping talking living doll.....;)
Reply to Supplying a converted Bus in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
I need to handle power failure for my electric strikes in my house. Of course, I can leave the keyed entry on the knobs, but what if I wanted to...
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
