Discuss Surge Protection in the Canada area at ElectriciansForums.net
L
Lifeguard
Hi,
I have a combi boiler fitted in a local community hall that blew a circuit board due to a power surge last year. This was rectified at the time by the fitting of a new circuit board. The boiler is connected to the electrical supply by means of a switched fused spur.
Does anyone know if there is a surge protected spur on the market that I can replace the existing on with and prevent further problems? I dont want to go down the line of using a plug and socket as users then to pull the plug out and leave it cold for the next person.
Any help will be well appreciated
Yes there is such an item on the market, not sure but i think its manufactured by powerbreaker. Check out a quality wholesaler for information. If it proves difficult to get hold of you could change the spur to a socket and fit a surge arresting plug as these are available quite easily.
Reply to Surge Protection in the Canada area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi I always thought installations were safe at the time of instalment etc, the Distribution Boards at my works were installed over ten years back...
Hello! I'm struggling to find an answer to this question online. I'm new here btw - I'm a DIYer with a physics degree Currently when my fridge...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Ok, installing a new CU with type 2 SP. The installation has an existing PV 6 panels protected by a 16a MCB at the fuse board. TBH I don't really...
