Discuss surge protection in the Australia area at ElectriciansForums.net
i have 1 of these to wire up this week and im not to sure how these are wired up
basically its a home office with dado trunking with 20 single sockets these will be made into the ring and at the end of the trunking will be the surge protection and breaker in an enclosure
any advice will be helpfull
Never wired up one of these myself either, one question tho, will you be running a additional CPC with your ring circuit for earth leakage or isnt it required in this situation?
nope nothing like that
its like a rcd unit what you would use for showers etc can only fit 2 breakers in 1s a breaker and 1s a surge breaker
it has 1 other side of the office had a quick look and i still couldnt figure it out i dont wnat to just wire it the same as that could be done incorect
it seems to have 2x from the breaker to the surge
all earths into the bottom of the surge
2x neutrals crimped together
2x neutrals together
2x line crimped together
and i think the other 2 went into the breaker
i should of got pics as that may of helped
the only surge gear ive fitted goes in an enclosure next to the cu you just feed it off an mcb in the cu and it protects all outgoing ciruits.
how do you wire them up this will be same as what you have there but it will be in the ring and just done for them sockets
i have no idea how they work and no one at work does either
Hey mate.
Who makes the unit your installaing, have you seen it yet??
Might be able to google the manufacturer and find some tech info on the website maybe??
Cheers.
Hey mate
I found this.
Installation and connection​
The main protection SPDs are
installed directly after the main
incoming switch or RCCB
(type S).
SPDs can be used in any supply
system e.g TNCS, TNS, TT.
Options: Replacement
cartridges.
Connected in parallel to the
equipment to be protected.
Protection is assured in both
common and differential modes.
Also If you look at page 66 of the PDF you will find all the wiring diagrams for them.
Hope this helps.
Hey mate
I found this.
(type S).
cartridges.
Hope this helps.
you my friend are god
iv found the diagrams and it makes a bit more sense now
SPD's normally fitted upstream of rcds afaik (unless rcd is time delayed )-to prevent nuisance tripping - and wired in parallel with loads to divert surges(via earth)
the high-integrity earthing is for 'standing leakage 'over 10mA afaik =it will prob prevent a dangerous touch voltage if a screw works loose etc
it's not to handle leakage as such-it's to ensure the integrity of the circuit cpc
Reply to surge protection in the Australia area at ElectriciansForums.net
Scenario: Commercial TPN distribution board down stream requiring type2/3 protection. Board is at full capacity and breakers discontinued etc. how...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi Can anyone clear up or explain in a bit more detail what could potentially be causing the results I have. I have just tested a 32a ring main...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
