Discuss survey PIR in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Peter Woodford
could you tell me if this is correct. I have been asked to carry out a electrical survey PIR and saw on a thread that you do not have to be registered to do this is this correct i have 236 and part p nic
many thanks
Have 236part 1and 2 so I would say I know what I'm doing how much do you normally charge for one of these
Also part p
Peter,
It is not as straight forward as you think,
One way of proving competence is qualifications and for performing PIR's the C&G2391.
If your PIR's were ever in question, this would help your case, along with your professional indemnity insurance.
Peter,
Ok thanks so do the 2391 first thanks for your help
You don't have to do the 2391 but it helps, it's down to you to access whether you are competent enough to carry out a PIR. Personally i do not have the 2391 qualification and I probably carry out about 7-8 domestic PIR's a week. Its down to you at the end of the day but i would advise doing your 2391, hopefully i'll get mine done over the next few months.
yes peter 2391 is way foward but dont think it is easy you do a practical exam and a closed book theory exam with detailed reasons for various scenarios but i feel if you can crack that you would have gathered some experiance by then.ps it was 3 or 4 years since i done it so it might have changed.but good luck
How much do u roughly charge for a pir
Reply to survey PIR in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
I needed to illuminate our dark side walk at the house. I have used two PIRs wired in parallel which switch four LED lights. The idea is no matter...
Hello, I am in the process of purchasing a property. I have made an offer, and after my own little survey, I noticed a few issues with the...
