Discuss SWA connections................ in the UK Electrical Forum area at ElectriciansForums.net
What would be a recommended way of creating a 3-way connection in 4mm SWA? I have had a look at Hylec Tee connectors and other such things but what would people recommend? I am a bit limited for space as I am running the swa in a trunking which is shared with an MDPE pipe.
A resin branch joint is one approach, if you have the room. E.g. Branch Resin Joint Kit - SWA - https://www.swaonline.co.uk/cable-jointing/cellpack-resin-cable-joint-kits/branch-resin-joint-kit
If you don't have the width for the branch then you might be able to use a straight if the end is large enough to accept two cables without mangling it.
If you want it accessible and have 70mm or so width, a BESA trouser-box (Y box) might suit. The smallest glanded setup you could make would involve drilling a metal enclosure to suit. If you offset one gland behind another using a longscrew, it can be little more than one gland diameter plus 20mm.
Reply to SWA connections................ in the UK Electrical Forum area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
4K
In the UK, It is said that the neutral wire is connected to ground/earth wire along the way back to the substation. Ive inherited a setup where...
I am stuck on another job for next 2 months . Friend has maybe 14 max down lighters and maybe 2 pendant points . Wiring in loft space is a bit...
