Discuss SWA For meter tails? in the UK Electrical Forum area at ElectriciansForums.net
I need to upgrade my meter tails to 25mm. The existing tails pass along under the pebble dash in plastic conduit (which would be too small), then apparently at an angle through the porch structure (unprotected) then turn sideways into a void & up the void to CU.
I have seen other posts where the use of SWA is suggested but I haven't actually seen SWA with 25mm cores. "25mm SWA" appears to be 25mm "Outside diameter", so I presume that means the cores are smaller.
Any suggestions as to the best approach welcomed. I actually think I will struggle with getting SWA through anyway even if it does exist with suitable cores, because of the bends involved.
NB The meter box is under the window of the house rather than on the side of the porch, but the void inside the porch is set back behind the run of the outside wall so it's not possible to drill directly through the outside porch wall into it.
You can get 25mm SWA cable, and bigger.
Remember that if the tails are longer than 3 meters then you need to fit a fused isolator.
Why do the tails need rewiring? What is the Earthing system?
I bet anyone (a cheese cake) that the OP is talking about the cables from the meter to his CU....
Trouble is Spoon he aint talking much, been quite for a couple of hours.
I wonder how the cable conductors will be enclosed or the cable glanded for that matter.
Don't think the OP has factored that in. Offline as we speak.
We can talk amongst ourselves whilst we are waiting - let’s face it, we normally do!
Agreed it’s meter to CU. The Lord help him when he gets back to all the questions!
No one talks to me, so I have to come on here.... OK, hardly anyone talks to me on here as well.... :sob::sob::sob::sob::sob::sob:
‘A voice in the wilderness’
- @Spoon you get PMs from your ‘special’ friend @SWD so don’t go playing that tiny violin anywhere near us!
But I have to pay him to talk to me....
and he didn't even send me a PM.....
I think there may have been too many megabytes to send what he intended across the t’internet! Eeewh!
If he's sending d*ck pics then the pics would be very small...
Reply to SWA For meter tails? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
