Discuss SWA or conduit on cage room in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Need to run either SWA or steel conduit in an industrial environment by the room is going to be made from a mesh cage. 8 sockets and 4 wall mounted tube lights. Which would be best to fix to the mesh and what can I use to fix. I am assuming the cage would need to be bonded??
well it cant just be mesh all the way round without supports (box section..or angle)..maybe channel or universal....look, either way..there will be a frame to support the mesh so....
Two squares of suitably sized 12mm ply screwed either side of the mesh then mount the saddles, same can be used for sockets and switches etc.
There will be frame to support but not exact where sockets and lights are going..... So not straight forward as you're making out is it....
or some 50X6mm black flat....put your saddles up against it at regular intervals and drill through (you use the saddle as a template/pattern.....then just whip off the flat into blanks with a chopsaw.....be sure to remove any sharp edges/rags before using though wont you....
dont get truculent with me sunshine...i worked in fabrications for 15 years before sparkying....you are asking the right fella about this prob you have but any more of that and i wont bother..capish...
Suggestions for mounting sockets to wood panel is good but cable tieing swa is probably the best thing I can think of to support cable
well as its a cage,run some galv trunk around the top, fix with nut and bolt using flat bar as said to clamp down,then galv conduit drops,again using flat bar to clamp saddles same with fittings
What's the mesh cage room for?...sometimes this can dictate suitable fixing methods.
As an example the last steel caged room i did was in a local food factory (Nut produce area so had to be seperate from other are's for cross contamination) so had to be all Stainless steel...luckily it was an Electrical/mechanical firm so we made the cage aswell (hence my previous post about tac-welding fixing plates).......wasn't allowed to use any wood at all.
flat bar....hot rolled often refered to as `black flat`....you can get it on various widths and gauges....very common..any steelstockholders will have it.....that WILL give you the support you need for this scenario.....
probably a 314 or 316 grade stainless..which is food grade stuff....
anyway...if you fix the conny direct to the frame/mesh.. the cage would no longer be an extranious-conductive-part...but an exposed-conductive-part......
Reply to SWA or conduit on cage room in the UK Electrical Forum area at ElectriciansForums.net
I am going to need to install a small amount of galvanised steel conduit, leading down to perhaps 4 sockets and a light switch. This is in a...
4K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
