Discuss Swa to consumer unit - how to make it look neat? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
tomodo
Hi having to use swa instead of tails for a new consumer unit as its 6 metres from meter however don't want to be able to see the swa glanded off to consumer unit , whats the best way to go about doing this, consumer unit will be in utility room. thanks
what is the wall the CU is being mounted on i.e stud wall, brick etc? if its brick are you allowed to chase cables in?
its a stud wall, cant see how id bend swa round to come in through the back, only way I can think is through joists then butt the fuseboard up to the ceiling and come n through the top..
What lee said.
Chase SWA in to wall and terminate in to a Galv conduit box chased in flush and then mount the CU on top.
if it's stud you could mount conduit box on a noggin in the wall first, you would just have to make good the plaster work first before mounting the CU.
mount a nogging before its boarded with something you can gland the swa in to like a metal adaptable box or galv stop end box.
Edit: didn't see Wes1000's post :cool3:
Out of interest, why don't you want a SWA gland with shroud on, on show? I think it looks alot neater than tails entering a board but this is my own opinion.
You could use a flush mounted CU, and have the SWA and gland all concealed in stud wall. Gland in on top or underneath. Job done. All you see is the lid of CU. Tidy.
Fit some 50mmx50mm PVC trunking gland the SWA as normal using the trunking to hide the gland.
do it right. fit some unistrut and tray. make a feature of it. it's a utility room, FFS, not a princess's boudoir.
Nah, boxed into a riser, surrounded by a unistrut frame which is then drylined, then a cupboard built around that. Then wallpapered.
and a vase of flowers, FFS. bought the x-wife some flowers once. she said " i suppose i've got to open my legs now"'.. " Why", i said. "ain't you got a vase big enough?"
I have glanded into a metal knockout box in the past and contained it within a large plastic enclosure. Bit of a faff on to get it right and you will need an insulated enclosure pretty much as big as the CU itself. That was with 16mm 2 core though, anything bigger might be near impossible.
Personally,i would be very apprehensive,concerning chasing out,and concealing such a cable,in a utility room,where every white-goods dude,storage fitter and DIYer,will be wielding a drill.
Viewed a photo the other week,of some hero who had masonry drilled through a 4" brick wall,and through both sides,of a radiator,on the other side...
A nice piece of square trunking,can be worktop and cupboarded round,and can hide in plain view.
Reply to Swa to consumer unit - how to make it look neat? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
HI My flat just failed the EICR because there is no RCD in the consumer unit. There is no space for a new RCD as the consumer unit is full. Do I...
