Discuss SWA/wiska box/piranha nuts in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Some assistance please.
simple job really, 3-core 4mm SWA to be glanded into a box with a 20mm S gland, and piranha nut.
I'm not familiar with the Wiska brand, but as it gets a good name I thought I'd try a couple. Was looking at the 206, but frankly I get easily confused so maybe one of you might suggest the best box.
Thank you.
I think the whisker boxes are pre threaded to 20mm thus been plastic are not really suitable for swa earthing, the piranha nut simply will not fit, I would get a standard IP rated plastic box and gland as normal using the earth ring or piranha nut as required.
Aren't they threaded 20mm entries, P. Have a job on with the earth locking nut. Get the metal plate arrangement for internal earth linking.
I have some Piranhas though...
maybe just go with a plain box, and try the Wiska range another time.
so many plain IP rated boxes to choose from, so that's maybe my easiest solution.
I thank you all for your input...much appreciated, and gratefully received. :)
I personally have not tried a piranha nut thingy , I usually just put the bangos on the inside kink them up and bolt together,,,,
Yer missin' out, mate. I wouldn't be seen without them, these days.
Just installed some pvc 32A 3 phase/N/E 5 pin sockets with isolators. They leave drilling and linking banjos in the shade.
Do they go bang. by the way?
Piranhas are a good choice for compact stuff like isolators where a banjo simply is too big and sticks out past the edges of the box.
Reply to SWA/wiska box/piranha nuts in the UK Electrical Forum area at ElectriciansForums.net
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hi All any suggestions for a small adaptable box with dims approx 50 w x 50 deep (length not really an issue), the Wiska 206 would be ideal...
Help please. Firstly the kit I'm using. Wiska 607 box. 25mm knockouts. 4mm 3 core swa. 20s gland Wiska 25-20mm reducer Secondly the issue...
5K
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
