Discuss Swimming Pool Circuit in the Australia area at ElectriciansForums.net
O
Octopus
I've been doing a PIR today and to my horror and surprise I discovered that the only device, between the 60 Amp main distributors fuse and the pool pump was a 30A 10mA RCD (if you ignore the henley block, the 16mm tails! and the SWA)
Looks like some remedial work is coming up!
Given that the SWA is connected directly to the metal casing, and the RCD shown is the only one in the house is the best solution to remove the existing RCD and fit a 2 way metal consumer unit with a RCD and 16A MCB? Also would it be best practice to upgrade the tails too?
Comments please!
if its the only rcd in the property why not suggest a board change and put the armoured supplying the pool directly into the new board with rcd protection
I'd thought about that and yes it would be a reasonable suggestion -however they currently have 19 circuits and should really have at least 22!
It will all depend on their budget!
Any other views appreciated.
Reply to Swimming Pool Circuit in the Australia area at ElectriciansForums.net
I incorrectly posted this on the "electrician's forum" and got a bit of a cold shoulder. Looking for some tips on supplying my pool equipment...
Can someone sanity check my thinking please.... An 80 amp PME service head, tails to meter, 25 sq mm tails into an enclosed fused isolator with...
V
Hey guys, i have started to do some inspecting and testing, i am finding it very interesting although the certification part is a little confusing...
4K
Went to look at a job the other day, The customer wants some "electrics" installed for his swimming pool, pond, and jacuzzi. Had a quick look at...
Ok, so I'm registered with Rated People. I don't use them very often but once or twice I have purchased a lead that has turned out to be very...
