Discuss swimming pool cleaner in the UK Electrical Forum area at ElectriciansForums.net
what frequency is the pool cleaner designed to run at. this could be a problem.
if the gear says it'll work on 50/60 Hz, then it's OK. if it were stipulated as 60Hz, the any motors would run slower and maybe overheat.
Reply to swimming pool cleaner in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm trying to understand legislation in the UK for using an air pump in conjunction with a swimming pool with regards creating and supplying...
Hi all, Looking for some tips on supplying my pool equipment (2kw heater, 1hp pump, 1.6kw swim jet, 12w led light) with power. My house has a...
Hi, I hope that someone here might be able to put my mind at rest. I have an engineering mind and a reasonable understanding of electical work...
I incorrectly posted this on the "electrician's forum" and got a bit of a cold shoulder. Looking for some tips on supplying my pool equipment...
Hi All, We've done some electrical in the past. Wired our outdoor kitchen, added an electric heater to our porch, etc. We are pretty new to pool...
