Discuss Switch gear / Panel board Rating in the UK Electrical Forum area at ElectriciansForums.net
The Incoming breaker model is Terasaki - S250-PE, 250 Ampere Frame rated for which Ics is 70kA, Category A breaker
The outgoing breakers model is Terasaki - H125 NJ, 125 Ampere Frame rated for which Ics is 85kA,Category A breakers
The bus bar rating is 65kA for 1s.
How should this panel board be specified, 65kA for 1s??. Since both the Incoming & outgoing breakers are of category A breakers, Is it correct to mention the time rating along with the short circuit?
Generally, How is the panel board short circuit is mentioned in the name plate of the board for which the Incoming & Outgoing breakers have different breaking capacity?
What does the rating plate state and do you have the test certificate. They are normally rated to the busbar section withstand.
Reply to Switch gear / Panel board Rating in the UK Electrical Forum area at ElectriciansForums.net
Is it mandatory to have the bus bar rating equal to the Ampere Frame (AF) of the Incoming Breaker (MCCB) in the MCC, sub distribution panels. Is...
