Discuss Switch probe? in the Electrical Tools and Products area at ElectriciansForums.net
read the instructions that come with the instrument. they tell you what i'ts for and how to use it,
contact megger. download full instruction manual
[FONT=&quot] [/FONT]
[FONT=&quot]ILLUMINATED SWITCHED PROBE SPL1000 (MFT1502/1552/1553 ONLY)[/FONT]
[FONT=&quot]The Illuminated switched probe accessory replaces the RED 4 mm test[/FONT]
[FONT=&quot]lead. It can be used anywhere that the 4 mm lead set is specified in this[/FONT]
[FONT=&quot]user guide, and it will also add extra resistance to a loop test measurement.[/FONT]
[FONT=&quot]Operation (SPL1000)[/FONT]
[FONT=&quot]The YELLOW button duplicates the function of the TEST key on the[/FONT]
[FONT=&quot]instrument, allowing quick and easy testing.[/FONT]
[FONT=&quot]The BLACK switch operates a white LED, which illuminates the probe tip[/FONT]
[FONT=&quot]for use when testing under low light levels.[/FONT]
[FONT=&quot]There is also a visual indication via a red/green LED to notify the user of[/FONT]
[FONT=&quot]the display status, the meanings are as follows:[/FONT]
[FONT=&quot]Green : A valid result is present on the display or the[/FONT]
[FONT=&quot]continuity buzzer is buzzing.[/FONT]
[FONT=&quot]Red: A warning is being shown on the display, testing[/FONT]
[FONT=&quot]will be inhibited.[/FONT]
Reply to Switch probe? in the Electrical Tools and Products area at ElectriciansForums.net
Bloody specific fitting megger test leads! I've lost 2 of my megger probes now. I have plenty of crocodile clips and the long, thin, bendy probe...
So bought a second hand Megger BM233 to practice with as I'm a college student.. So I was just using it on a loose 2.5 cable. Testing on the...
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
Hi guys/gals, Had a message from an old customer from my old firm whos having problems with their stat. They have 3 electric ufh using the same...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
