Discuss Switch switchover - wiring advice in the UK Electrical Forum area at ElectriciansForums.net
01jTZPAN-pb9MUjnqQ6l_jiyQ
HI I've just had a gas fire replaced with an electric fire. The old gas fire had a brass double switch at the side of the fireplace which controlled the fan for the powered flue 1=low 2=high (I forgot it was a double switch its been so long since we used the gas fire). Anyhow I've just bought a chrome fused spur switch thinking this is what I was replacing. I'm now at a loss to know what old wires go where and whether using the fused spur switch is a good idea. Surely it can't harm given its controlling an electric fire which will draw more load than it did in the past. Old in situ wiring and new socket connections shown. Any advice welcome
You say you've had the fire replaced - was it fully wired and working when this was done? Who did the work?
Reply to Switch switchover - wiring advice in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
