- Reaction score
- 2
When you put in a built in appliance in a kitchen which is fed from a switched fused spur, do you hard wire the supply or keep the plug on with the 13a fuse. Personally I'd like to hard wire it but then this will make the products guarantee void, so you could still end up with the issue of having to pull out the appliance because the fuse has gone.
How do you get round this?
