Discuss Switched live in fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi,
Just reading through 'Connections' (ELECSA's magazine).
Found an article saying it was aright to use the green/yellow for a SL in a class II fan if you sleeved it both ends with a brown sleeve.
They cited 514.4.3 which in my book refers to PEN conductors saying it overrides 514.4.2 (thou shall not use the protective conductor for any other purpose)
Is ELECSA right?
Cheers
s
Thanks T,
Read the thread. My point is that the CPS (bothe NICEIC and ELECSA it seems) is quoting regs to back up their case that don't have any relevance. Like most people in the other thread I'm not going to start using the cpc as a live conductor!
Cheers
s
Except that 411.3.1.1 makes it impossible to do.
I would blame NIC (rather than Elecsa) as they often make up their own rules.
I wish people would read the BGB and not take notice of all these guides, best practices, magazine articles etc.
Seen this a few times especially in room stats, 3 core flex with the green and yellow used as switch line.
www.meadelectricalservices.co.uk
hi,
Is ELECSA right?
Cheers
s
$250,000.00 fine here if you use a G/Y conductor for anything else than ecc, the problem is that someone could cut in the middle and not know that it is active (live for you guys) and bang their gone
Reply to Switched live in fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
can anyone help with the connection for the switched live from the bathroom fan in this fuse box. it is the unconnected yellow wire with a red...
I was reading the latest issue of the NICEIC’s Connection magazine, when came across an article about wiring extractor fans. I didn’t read it in...
8K
Outspoken
O
M
Just a thought to put it out there. Why not make the coulours that ID our conductors more simple and standard. Way back when I did my appieyship...
Hi folks, This is my first post on EF,so go easy on me please ;-) I'm having issues with an inline extractor fan I've installed at my own home...
6K
I carried out the new PIR / condition report today and found a diy bodger had added two way light switching, in flex ,using the cpc as a live, in...
14K
Graeme Harrold
G
