Discuss Switched maintained emergency lighting system in the Australia area at ElectriciansForums.net
G
gerard
Hi,
As part of my project I have to explain how exactly does a switched maintained emergency lighting system works? Also, how what is the best method of testing such a system and how often. the emergency lighting system will be in a supermarket.
Cheers
Thanks for that. So, in the Supermarket there will be rows of lights for each aisle. I will have to locate a test switch somewhere to test the lighting. Does this switch just knock off power to the normal lighting and allow the emergency lights to operate and be tested, when required? Would you recommend having one switch for all the lights or dividing them up into circuits?
We put an emergency key switch in per circuit. All it does is cut the permanent feed of your 3 core to simulate a power cut.
I'm not sure on how often they have to be tested, but every 3 months seems to be ringing a bell but I'm not entirely sure.
Reply to Switched maintained emergency lighting system in the Australia area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
