- Reaction score
- 24
Cab anyone help me with a reference method for T&E running under the floor in a domestic situation?
Also, I assume that the reference method applies to the method that describes/applies to the longest section of the run. I have a 1mm cable running on the surface (1 metre) from the CU, then through a ceiling into the floor above, running beneath the boards for about 2M, then up a service void, then over the ceiling (under insulation) to a joint box distributing to the lights.
I've boiled it down to B, D & C thus far using tables 4A2 & 4D5. But there are so many other general options :sick:
