Discuss Table saw switch in the UK Electrical Forum area at ElectriciansForums.net
Andy5678
Looking to replace a table saw switch. The saw has a slow start motor, so the usual retrofit start stop switches won’t work.
Anyone ever replaced one/recommend a retrofit switch?
Andy would a selector switch work ?
[automerge]1582400647[/automerge]
It would be an HOA selector switch with on-off-automatic
Are you sure the switches are the source of the problem and could they not be standard panel mount and working a soft start unit? Do you have any spec or pictures of the saw at all?
No pictures. Had the switch open, it has a coil
In it, when the start button pushes down into it. It has 3 cores and earth going into the motor. Switch is defiantly faulty as it’s seized and melted at the base.
Ah I see, no mistaking that then! Sorry bud I wouldn't know where to get a replacement or similar, I take it googling the make and model is not bringing anything useful to light?
Found the right switch but it’s expensive and probably better getting a new saw. But if other switches are available, it would be a better option to replace.
Just how many terminals are on that switch, it sounds like it is opening and closing the load of the motor not the wiring going to the coil which starts the motor
[automerge]1582406879[/automerge]
The switch should be turning on and off the controls not the actual motor load. Most switches are not designed for that much current
It sounds like it might be a star delta starter to me. If so, get an experienced electrician to sort it out.
edit. Are you sure about the number of cables involved?
Reply to Table saw switch in the UK Electrical Forum area at ElectriciansForums.net
I have a ring cct (2.5mm ) in my cabin which is protected by a 20amp RCBO. This has been in existence for over 3 years with no issues. I recently...
Hello Everyone -- So, I am looking to buy a used 5HP 3PH 208 V 10 inch Table saw --- (Motor Plate Data in Image) I am a DIY'er and in...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
