Discuss Tell me if this is going to be an issue in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Supporter
Patron
Don’t bite my head off, I’m not used to installing radial circuits. Just the odd spur, or an rfc if new circuit.
Between being Sunday, man flu and an early alarm... my brain has stalled.
A while ago I ran a spur from 32A rfc direct from the mcb to supply a new double socket in my hall. Only gets used by Henry... or the new guy: Dyson.
What I am wanting to do is make a utility room with washing machine and tumble dryer, and maybe another double socket. Easiest plan is to use that spur from earlier, put it on its own 16 or 20A mcb and make a radial with hall socket on the end.
Question is, are radial circuits ok for a couple of high power appliances and possibly dyson on all at the same time, or would I be better installing a 32A ring for just these 4 points?
Get a tumble dryer, that would be less of a problem. :)
washer and tumbler together on heat cycle is c. 20A. a 20A radial will be fine unless you plug in excessive load on the other double sockets. i'd prefer a 32A RFC
That’s what I was thinking @telectrix if I want to use the vacuum cleaner as well.
@Baddegg ive already got 2.5 in as the spur... was just going to reuse that cable as it’s buried in the wall for the last metre or so.
Always got 2.5 cuttings in the van.
So it’s either a radial, or a ring for the machines and a spur to feed that hall socket.
I think you’ve answered your own question. If you can’t run a complete new cable of a size of your choosing and 2.5mm is already installed then under those circumstances I’d run a ring final. It would then also ‘future proof’ you to a degree when wifey adds more domestic cleaning machines et al.
Ok. What I’ve done is left the hall spur as a spur. It’s off the downstairs rfc, so it makes sense to leave it.
I’ve run a new rfc into the new utility room, leaving scope for additional sockets if need be.
Got the plumbing to do now, and some joinery work.
Hanging a door is easy, right?
ask the guys in Hartlepool. they used to hang plumbers monkeys.
Just make sure you have a sharp chisel :p
I’ve got a screwdriver. Will that do?
Why is it, when there’s tradesmen in the house, my wife is very accepting of dust, a bit of mess and noise... always at hand with a cup of tea or a round of bacon sandwiches...
but when I’m doing work in the house, it’s all
“Do you have to do that now?”
“Are you going to clean up afterwards?”
“Do you know what you’re doing?”
Not quite as bad as my mum... who still tells me to be careful when I’m 2 steps up on a ladder
In the US the tumble dryer requires a 30 amp service at 240vac, washing machine requires a 20 amp 120vac isolated circuit. I don’t know how y’all do it or the current on the dryers and washing machine in the UK
our machines are only 10A each so generally plug into the socket circuit. in OP's case, it's a combined washer/dryer,so it'sphysically impossible to have both parts working simultaneously. it washes then spins, then tumble dries in sequence. don't forget, all our appliances are 240V so 1/2 the current you's need at 120V.
No sure of my load of our washer dryer, apologies I meant washer dryer in my previous post, but it runs off our 13amp sockets. It has an ++A efficiency rating, so shouldn’t be using the fall amount.
Reply to Tell me if this is going to be an issue in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
