Discuss Temporary workaround - power to garage in the UK Electrical Forum area at ElectriciansForums.net
Raggy
Hi guys,
I need to run power to my garage. At the moment, I've gotten away with wiring a long extension cable. 13A Plug on one end, cabled to double female receptacles at the other end.
So far that's worked fine as I've only used a LED light and some other low powered items. I just unplug from the house when I'm finished, roll up the cable and leave it in the garage for next time. Got nowhere near 13A.
I now need much more power available in the garage for heaters, tools etc.
I have a medium term plan for this - my back garden is going to be dug up later in the year and I'll be calling in a pro to run SWA from the mains, under the new garden surface and into a consumer unit in the garage.
My question is this - is there an easy way for me to temporarily run more power to my garage, in a similar fashion to what I'm currently doing? One piece of equipment will be drawing over 15A alone.
Any advice would be great. Thanks.
You could also maybe have the armour clipped to the fence or similar, and leave a bit of extra hidded behind the shed. This would mean its not going to get disturbed and you can just bury it when the garden is dug up and have it rr terminated if necessary.
As Pete posted either get the planned work done or as Vort posted a generator. I would say the first option of getting it done sooner.
Do your neighbours like you?
If you do this, they won't. Especially if you buy one of those cheap, open frame jobbies from a DIY shed.
true, but the bonus is it may drown the sounds of the neighbour's squealing bratts as they fart around in the garden. we had that for a year till the sods were repossessed, 4 screaming female under 11's with a trampoline. had to turn up Pink Floyd and AC/DC on the hi=fi to drown the buggers out.
Reply to Temporary workaround - power to garage in the UK Electrical Forum area at ElectriciansForums.net
The air conditioning on my Vauxhall Astra J has stopped working and I'm running out of ideas on how to fix it. Steps so far: The compressor clutch...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
I thought I would take a few minutes to give my recent experience in wiring a large garage for power and an alarm circuit. This relates to clipped...
