Discuss test & inspection meter -tail codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
F
fixit4u
i have been away from test/ inspection for a while and have got 3 months work on student properties ready for the new year.
I am enquiring about the meter tails, most of the propties will prob be 16mm tails and 10mm earthing so on the forms would i be correct by putting this a code 3 ,
will have a read up before next week so should be ok with the other codes but just unsure over the tails business
thanx for any replies folks
im not sure if i am right but if the main cut out fuse is 100amp i would put it down as c2 and and if its an 80 amp i dont see what would be wrong with it
You could code it C3 but unless the supply is 100A and/ or TNCS then it is very likely to be fine.
If there is no sign of damage in a long term installation then it could be noted on the cert but not coded.
if its marked as 80 then you have to take it as that and if it turns out later that its a 100 then its DNO problem as they install it and its their equipment
Reply to test & inspection meter -tail codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Morning, Company had an external contractor coming in to complete an EICR recently. They have gave us the report with a C2 for holes in trunking...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
