NAPIT Certification Scheme Test sheet
Discuss Test sheet in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Am I right in thinking that when filling in an installation test sheet for a sub board that is fed from an mcb in another its that mcb rating i put in the supply characteristics and do another sheet for the supply board with the intake fuse for that supply characteristic? Thanks
Reply to Test sheet in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Hi, Main LVAC Board, Directly Fed from a Transformer. What do i put as an OCPD on my BS7671 Test sheet? Since I don't believe the Transformer has...
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
When doing an EIC for an additional circuit (which only covers that circuit), does the 'main switch/switch-fuse/circuit-breaker/RCD' section refer...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
