Discuss Testers for Homeowners (e.g. non professionals) in the UK Electrical Forum area at ElectriciansForums.net
duckie
Hi - Sometimes a normal person would need to check and test their electrical connections. There are testers which claim to help do this job - my question is are they OK to use as a starting point to figuring if there is a problem in the first place? e.g. socket earth wire not connected which can be quickly tested with the socket tester
Here's one I purchased recently from Amazon that helped me find a socket which did not have its earth wire connected which I thought was a good use of the tester. Tester on Amazon
49921
useful as you describe but as Andy said, limited. e.g. they won't detect a N-E reversal. but end of the day, a useful DIY tool. we all carry one in addition to "proper" test gear. main use we find is checking which sockets are fed by each MCB without the encumbrance of a Megger.
What is it you are trying to achieve with these testers? Are you regularly using them? Just diying or more at home or elsewhere???
Reply to Testers for Homeowners (e.g. non professionals) in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
