Discuss Testing a new garage suppy in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I understand that this will require a new installation cert as I’m adding a new circuit from my main consumer unit out to a garage consumer unit via a 6mm SWA cable.
How do I add this to the test cert as a new supply. If it was a cooker supply for example I’d just add it as cooker put the relavent MCB info in and do the tests.
On the first section of the cert talking about that board ratings and earths etc Iv obv put Down the main c/u details. Where do I reference the new garage c/u and would I issue a separate certificate and simply put garage supply on my original cert with that words ‘see cert 2 for details?
I would produce a cert with two boards and corresponding schedules of results.
The first being the main DB, that would list just the new circuit (and if appropriate the associated RCD) whilst the second would list the new garage DB and it's circuits.
I would do the same but reference the exisiting circuits on the first DB as ‘Existing Circuit’ and N/A all the boxes.
According to his other thread he is a scheme member so I am not sure why he cannot put together a rudimentary Certificate.
I would issue new cert containing 2 boards. The first cert...all original circuits marked as "not tested (or whatever your dropdown list contains) and new circuit as "sub-Main to Garage" with results as applicable.
2nd cert containing all garage circuit details/results.
Reply to Testing a new garage suppy in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
I have supply in the garage with its own small consumer unit with a 63a breaker and 1 B6 and 1 B16 breakers. The garage has a ring of sockets...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
