dbrennan
Hi all im new to the site, hope all ok.
i have just re-wired my garage for the purpose of getting registered again.
The garage is fed from main consumer unitby 2.5 t+e and then joins a swa, which is all existing.
I have re wired the garage, put a 2 way rcd unit in, 1 ring main, 1 lighting circuit.
Im struggling on how and what test cert to use, obviously a new electrical installation cert for the garage behond the cu, but will i be required to test the existing swa that feeds the garage?? im assuming so, but on what type of test sheet, i no this is fairly simple stuff and have been in trade over 10 years but i acnnot get my head round it, for example, when i take a ze reading at the garage cu realy this is the zs reading from thre main cu, what tests and certs are going to be required. im struggling not with the testing itsself but more were to record and what bits i should be filling in etc etc.
thanks in advance
thanks in advance
