Discuss Testing CBR units in the Electrical Engineering Chat area at ElectriciansForums.net
CBR units appear difficult to trip time test on some occasions. Not only myself but other colleagues too when testing 300ma/500ma CBR units find even using a variety of manufacturers instruments that multiple trys are required before a succesful trip test. Often no trip occurs at all. Is this impedence related. ie TT systems.
I'm not good with acronyms so you'll have to remind me what a CBR actually is.
I know it's one of the permutations of an RCD, my guess would be its an earth leakage relay operating a circuit breaker via a shunt or release
Is it vigi type units which fail or seperate earth leakage relays with core balance transformers?
Core balance transformers need to be correctly installed to work properly, including getting the conductors centred in the coil, not off to one side etc.
Seperate controls. You know the type. 3 "inch square panel small rotary knobs for time delay and Current setting. Core installation complete in all cases. This issue is just occasional but given we install dozens annually the test failure rate though small is significant. It's a mystery though an Engineer from Kewtech did suggest that rcd testers specific to CBR units were available.
I know the type very well, I've installed a fair few in various bits of equipment.
I've never yet had an issue testing them, I usually test them at 30mA and a randomly selected higher setting.
At the moment I can't think why they would not pass testing with a normal tester.
Thanks Dave.
If we ever discover the answer I will be sure to let you know.
Reply to Testing CBR units in the Electrical Engineering Chat area at ElectriciansForums.net
A friend of mine asked me to look at here PV system as she is not getting any power (and thus money) from it. First real issue is the Aurora...
5K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
BACKGROUND I live in a small town where it is difficult to find ceritified electricians. In fact, electrician certification is not common for...
