Discuss testing code for ferrous consumer unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The regulations specify that L N and E may only be collectively enclosed by ferromagnetic material when entering an enclosure. And this has been a regulation for longer than MK have been making CU's so nobody can even say it complied with previous regs.
But is it potentially dangerous?
It isn't in normal use as the eddy currents from currents less than 100A are negligable. But under fault conditions there may be significantly more current flowing and much bigger eddy currents.
Reply to testing code for ferrous consumer unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
