Discuss Testing Ex display in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
You should be testing these lights without the bulb in place, as a Class II appliance. On most testers you can override the load check and continue on through the test sequence.
As per Lister's post #6
In the video you see an animated switch symbol to the left of the probe symbol at the bottom.
The manual says that switch only appears as a warning message:
"General Warning - Appliance open circuit or not switched on"
It seems the Megger is expecting to see a load, presumably in the automated Class ll setting I guess you are using.
If I were you I'd obtain from somewhere a filament bulb that fits the display lights you are testing, and see if that is a simple fix! Incandescent bulbs are not 'banned'. Shops with stock can still sell them, but now shops are not supposed to be buying in any more.
Reply to Testing Ex display in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
Evening. Got my hands on a pair of choke ballasts to run fluorescent tubes a few days ago and I want to see if they're in good condition. If...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
