Discuss testing live wires in the Australia area at ElectriciansForums.net
T
tadders
Hi guys, I'm after advise on checking live wires. Do I need a circuit tester or can I use the Electricians screwdriver I have, and if so how does it work. Many thanks
sorry, mate. if you are asking that question, electrics is not for you.
sorry tadders, i was a bit abrupt there. the neon driver is a no-no as it utilises your bodt for an earth path. what you need is an approved voltage tester, either LCD or LED. a volt stick is a good approximate guide as to whether a cable/circuit is live , but not to be relied on.
honestly, mate. that neon driver you,ve got is best kept for picking your nose.
so... edison didn't invent the light bulb, he invented the light lamp. all is become clear ( or is it pearl)
No tecnically it is a lamp not a bulb, like Ian I was taught very early in my career that bulbs are something you stick in the ground.
It came about like hoover for a vacuum cleaner, as the incandescent lamp in a house is bulbed shaped it just stuck.
but her lamp had a candle inside it. so a lamp it the whole light unit, later versions , obviously came with a candle bulb, not a candle lamp, as that is what she had in 1875
aren't genies made up of DNA
not when it's a daffodil
Your bored aren't you mate
yep. her indoors is outdoors, just done a fire alarm call-out ( pushed in glass on a call point) power washing the patio, but it's too cold and my feet are wet. sod it, going to the offy for some beer.
Reply to testing live wires in the Australia area at ElectriciansForums.net
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often. The chandelier is in a hallway controlled by a...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
