Discuss Testing of a new circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I know the logic in this doesn't make sense... But
If you install a new circuit in a 17th edition plastic consumer unit, but changed the consumer unit to a metal one the following day... What certification would you need?
Would you need an EIC for the new circuit? Or would you just include the new circuit on the EIC for the new board?
I know it's not logical... (You'd change the board first for obvious reasons)
Any information will be greatly appreciated.
And in England and Wales they both fall under part P too....
Hmm. Sorry, but I'll get my pedant horse out...
ALL electrical work falls under Part P
The
Statutory Instrument
Information relevent to Part P of the building regs in England/Wales, SI3210-2004 incorporating SI652-2006:
for Part P says only this
4f600d0d3fb42a8fbecd8f03b02da195
That is it.
The Building Regulations approved document (which you may be referring to) details how the P1 Statutory Instrument can be complied with. For instance, it suggests that conforming to BS7671 might be one way to do this!
It also specifies that certain work needs to be notified to the local authority. Which is a different thing.
Reply to Testing of a new circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys, need a bit of advice, EICR was completed on the property which needed a new consumer unit and a few other bits like broken sockets and...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
NICEIC Certification Scheme New Circuit - NO RCDs
A client wants an outdoor socket installing on a new circuit. The current installation doesn't have any RCDs for the other circuits. I would put...
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
