Discuss Testing Phase to Earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Guest 004
Anybody know of any testers that WILL not trip an RCD/RCBO when you test phase to earth?
Apparently this one does not
NrDQL095atrKvx-8kS3ikgTKt8MaA4ZitBZcN1txhxD9kGklemVRIH6x9eDLoH611xm1dkxYExIifDWeD75BDzv9e56u6cc-at2p7MHq94mHP2DDv0LpFzH_Bm3I1-qArXWvwR_xh5onCCFJwVXiZ4kBxhJny4eXisJM3Q
Or you can pay a bit more, buy the one pictured in the OP, and like Len and sintra say it will not trip a RCD regardless of test sequence it's also the best voltage tester on the Market, I don't know how I managed before I had mine
Have one, but don't like them really. Prefer my cheap version Fluke as a voltage indicator.
Reply to Testing Phase to Earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
