Discuss Testing PV Install in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
Mark Davey
As i'm fairly newto the PV market I wonder if anybody can confirm whether or not it is acceptable to use the information obtained from the inverter for the required test results? rather than phisically conducting the test?
The test results you need/want are Voc and Isc, which the inverter won't measure for you, it can only measure Vmp and Imp.
It also won't do the insulation test for you!
Pretty much that ^ I can sometimes be testing 20 a day and it doesnt really take that much longer to do it properly, just a few screws. If your trying to save time doing the testing make up a DC testing box with flying lead poking out.
Hi. Might it be a good idea for one of you experienced installers to make a test and inspection video to help all the new guys to do the job to a high standard, hope that dos`nt sound patronising, i`m the head of sales so i dont get to see any testing either.
Reply to Testing PV Install in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi,first off this does not relate to work I intend to DIY. I'm trying to sanity check information I've been asked to provide to the installers. I...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
