Discuss TESTING R1 + R2 garage supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
iceman
hello im tryin to get ready for me assesment with the nic iv got a ring final circuit upstairs witch provides power to the central heating off a fuse spur when testin R1 + R2 do i test all sockets and the spur or just the sockets? thanks
also theres a garage supply comin frm a 20A circuit breaker frm the house providing power via a fuse spur 2 socket outlets and 3 light points when testing R1 + R2 do i test every point including the spur? thanks
yes the sockets are on a radial circuit when i practicing i went straight to the furthest point but on the day the asseser will probley want to see me test every point :-/ lol
Just out of interest, why would he want to see the test at every point?
Edit. Duuuhhh. Just realised what i said.:D:D
Sorry, i've been out in the fresh air all day.
why would you take a R1 + R2 on a radia (R1 + R2 only on a ring)l and how can you take a R1 + R2 reading on you central heating surly it would just be a R2?
One point to bear in mind is that if measuring on the load side of a fcu the acceptable value will depend on the rating of its associated fuse and not the circuit protective device at the consumer unit.
spark1
Because you are measuring the possible fault path of that circuit to see if it is within the limits required
sorry i thought you only nedd to take a R1 + R2 reading on a ring, just new to testing tho.
Reply to TESTING R1 + R2 garage supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi everyone, I've got a garage with a circuit that looks like this: I believe it's a radial circuit coming out of the MCB with a current...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
