Discuss Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
ONIT
Afternoon,
Looking For A Bit Help, Changing A Light Switch For A Dimmer Switch/box Bedroom One Light-one Switch.
With A Minor Works Cert, What Tests Would Be Needed (were Do You Start And How Far Do You Go)
All Replys Welcome Cheers
if you doing a minor works for this (and i am not sure that i would)
Do R1+R2, but you will probably have to short out the dimmer, while its shorted out, do IR, then do Zs, then reconnect it
Thanks Shakey,
I Was Thinking Of Disconneting Switch Doing Ir On Switch Wire Then Reconnecting And Doing Zs From C/rose Got Niceic Coming
you might have difficulty doing Zs through the dimmer, your meter may not pull enough to trigger the triacs in the dimmer, and even if you do, it may give you a high reading - but give it a go!!
Any Ideas Of What Tests Niceic Would Be Looking For, For A Replace Ment Of A Dimmer
Reply to Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
