Discuss Texecom Alarm System in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Do you mean you have'nt installed a system before or you have'nt installed a Texecom? Alarm systems are basically the same , it's usually just the programming that differs.
texecom systems are different, iv just finished installing one myself, if you pm me with the models of the keypads, control panel and any extenders i will find you the guides
Rob
some are very different beasts,you can normally google a texe manual,tho i think oldtimer might have a few texe ones on pdf,i think he uses premier,or it might be tel,i cant remember..
Without giving to much away on a public forum , in what way are the different ?
Ignore that question your reply crossed my post . I use Three b/band and it is so slow.
the principle is the same,as electricity is,but a simple domestic panel to say a panel you fit in a bank and everything in between have different values for monitoring a device,some systems have anti mask features where as the detector knows if it cant see what its protecting and reports this locally and remotely,different programming features,different ways of connecting remote modules ,signalling,it can be complicated at times..
Thanks for that I must confess mine are most r8 stuff.
if you still havent got the manuals pm me you details and what panel it is you need, i have them at home will email em over later
Reply to Texecom Alarm System in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I’ve recently moved into a property with a Texecom premier elite system. I’ve been given the engineers code and have read up on the alarm. It...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
