Discuss texecom panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi guys, just wanted to know if any of you use Texecom alarms. Have to install one for my father in law and wanted to know how hard they are to set up. One of the guys we work with commisions but i'll no doubt end up paying!!!
texecoms are easy to set up. just follow the book. only thing i found with one i used was that to prog. a zone as e/e you enter code 6, when logically you'd use code 1.
Texecom very good system easy to program, you should not have any problem....Premier series are more advanced, but not beyond most electricians
haha. knowing you, you'll come back with a rottweiler.
certainly is. originally from rottweil, near stuttgart.
I installed a Texecom Premier in my house a couple of years ago having never touched alarms before. Was mostly pretty straitforward, but a few issues cropped up and Texecom support were very helpful.
A few tips from my experience:
If you use the higher end PIRs you only need to take the DC supply and alarm cables back to the panel, and set the resistance / type of PIR at the keypad, if you use cheaper ones you need a resistor in the PIR. I used T-EOL for most of my PIRs which were dual-tec, but needed resistors in the "pet-friendly" ones I installed in a couple of rooms downstairs.
I wired in two bell boxes as I wanted one on the front and one on the back of the house. I had some problems but can't recall what just now so send me a PM if you have this issue and I'll get back to you. You can also install the bell boxes to grade 2 or 3 and the wiring is different.
Use 8 core cable even if you don't think you will need it - it doesn't cost much more, and gives more flexibility (i.e. to wire the sounders to G3 I think you need 8 cores).
The first time I set the alarm and tried to dis-arm it, it refused and said something about needing a key-fob. If you have a keypad without this you can't and I had a brown trousers moment thinking the alarm would go off - it didn't but there is a setting to disable that. Also if you are not having monitoring disable anti-code reset.
Finally, be aware that if you state that you have an alarm on your house insurance, unless it is always set when you're out, the might refuse to pay up. For the tiny reduction in premium I wouldn't bother - but I think it's worth having all the same as I am sure that professional criminals can easily tell the difference between a bell box connected to a functioning alarm system and a dummy with a flashing LED inside it (unless you get a Yale DIY which has neither!)
I enjoyed installing the alarm and it works well but be prepared for some head-scratching moments. Let us know how you get on.
Richard
.you could change the PIRs for pet tolerant ones. acceptable body weight is around 80lb. can you posat a pic. od stig? love dobies.
Strange, I have a galaxy on my old house and a accenta on the new one, I've used neither since we have had "Stig" our 8 n a half stone dobie :)
Trouble is a dog unless trained to only eat on command is not an alternative to an alarm, I know of a few upset dog owners where poisoned meat was put through the letterbox prior to the break in
Managed to get the alarm up and running, pretty straight forward and the manual is very good, it actually tells you what to do in plain english!!!! Found the panel and equipment really easy to install, seems good quality. On top of the father in laws i've fitted one for her uncle and he has now given me a couple of jobs for friends and clients of his. Result!!!
Reply to texecom panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi all Is it possible to connect a Texecom Odyssey 1E sounder to an Optima panel using 4 core cable and still allow the bell, strobe and tamper...
