Discuss The current gain for the transistor under these conditions would be in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
turbomen
A transistor is set up in a test circuit and a base current of 12μA is measured. At the same time, the collector current is measured and found to be 2.28mA. The current gain for the transistor under these conditions would be:
(A) 9
(B) 19
(C) 190
(D) 1900
(E) None of the above values
Could you tell me how can I get the answer?
Proper head scratching stuff this matey.
I THINK the sum is current out/current in = 0.0228/0.000012 which gives the answer of 1900. So (D).
Fair play.
I changed my mind once already because of the decimal point.
To clarify then - 2.28milliamp = 0.00228amp (divide by 1000).
12microamp = 0.000012amp (divide by 1000,000).
So the answer would be 0.00228/0.000012 = 190. = (C)
I think:eek:.
Reply to The current gain for the transistor under these conditions would be in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
All - Would appreciate some advise or professional help as I'm facing a £4.5K bill following an EICR which seems to highlight issues that passed...
4K
Hello everyone I'm Chris. I am taking the 2391 in February. This question is from the c&g main site under 2391 sample questions. Continuity of a...
4K
