• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss The old one still learning in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hi guys me again still learning at 54.
Just doing some testing at home to get my head around things
Testing end to end of rfc and getting different readings on end to end of phase and end to end of neutrals.
Am I correct to be thinking a bad connection on an outlet somewhere as rfc wired in 2.5 t&e pvc so both phase and neutral both same csa ?
Tia
What sort of a difference are you getting? could be a week croc clip connection.
With an r2 of 0.84 that would imply that the neutral reading you got was correct (0.84 / 1.66 = 0.5). So I'd be looking at a fault in the line conductor, most likely a loose connection in one of the accessories.
Reply to The old one still learning in the Electricians Jobs area at ElectriciansForums.net
M
Hi Guys I purchased some of the above online around 3 weeks ago, They are a fairly new product, very usefull as you can change both colour from...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
