Discuss The use of plastic wall plugs for the 18th.... in the UK Electrical Forum area at ElectriciansForums.net
Spoon
Mentor
I was just reading an interesting post about the 18th when the above was mentioned. there seems some debate about this. I initially thought that the idea of prohibiting the use of them was stupid, but I'm not sure now.
http://www.swaonline.co.uk/files/ww/Install Protect _ ComplyFull Document.pdf
These walldog screws look like they could strip the hole easily in some cases.
Costly AFDDS and non plastic wall plugs are going to up the prices on any run of the mill Domestic work, in fact any type of work will start to increase price wise.
I have to agree mate, looks like dodgy Bob down the pub will be making a few more quid as the rest of us are out priced...
Agree with you there mate.
So what's your opinion on the use of plastic wall plugs?
Not sure Spoon, as I don't do much these days it's hardly an issue for me, although I will be asking the very question at ELEX in September at the Richo Stadium.
Plastic rawl plugs are perfectly fine. To think otherwise is nuts.
So the attachment which was taken from the IET report are both incorrect?
Fire performance of cable supports - https://electrical.------.org/wiring-matters/issues/58/fire-performance-of-cable-supports/
Would like to hear what they say about it.
That is a really interesting read and it would appear plastic rawl plugs do not comply.
So I have changed my mind.
Seems someone with such initial forthright views, has been able to change their minds (no offence meant) makes the issue all the more confusing, would like to hear what the scams have to say on the subject. without all the gobbledygook, just plain and simple for us Sparkles to understand, in black and white, not with shades of grey, and get out clauses, I suppose it's asking to much for a simple explanation.
Reading the report changed my view as well. I thought that plastic wall plugs would not be overly affected by a house fire, but it seems they are.
That's why I posted up the screen shot and the report for people to see. See what they think about it.
During Fire 1 the metal fold over clips secured by screws with a plastic plug were ok, if I read it correctly. And in the more intense Fire 2 they fell out due to plastic plug failure. The only question I have (so far :) ) - are the Testers saying my house will burn as per Fire 2? (based on?).
New posts
Reply to The use of plastic wall plugs for the 18th.... in the UK Electrical Forum area at ElectriciansForums.net
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
  • Locked
5K
What's the most badly designed accessory you've had to install? I present my nomination, the ML Accessories/Knightsbridge RWL5 wall-mounted LED...
One of the oddest jobs I've ever had today. Called by a plumber I know who had attended after a leak through the kitchen ceiling from bathroom...
6K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
