Discuss There was mirror with led lights,with no switch for the light from the power source .can rocker switch be use (240v Ac power soutet in the UK Electrical Forum area at ElectriciansForums.net
if the suply to the mirror is standard 240V a.c. then a 240V a.c. rocker switch (normal light switch, as in fixed to a wall) is ideal, as long as you are switching before the LED driver, on the 240V input side.
Not sure about your local regulations, a rocker switch will work as long as it is rated for at least the voltage being switched and the current.
In the U.K. there are restrictions if being used in a bathroom and it may not be suitable for all locations.
Will it work? YES
Is it to regulations? UNKNOWN
P.s. welcome to the forum.
they are available worldwide, just make sure it is suitable for the environment it will be installed in.
again, I cant advise on local regulations so if you are unsure then maybe check with a local electrician?
Reply to There was mirror with led lights,with no switch for the light from the power source .can rocker switch be use (240v Ac power soutet in the UK Electrical Forum area at ElectriciansForums.net
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi, I have two LED light panels (like this: LED Panel 120x30cm - Varm hvid 3000K-40W -...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
